Rebolting heads with same gaskets
Splinter
Post by Splinter »
Due to various issues of location and equiptment availible, Im going to have to pull the heads off my engine before I take it out of the bay.
I cant afford to do my rebuild right now, but I want to start work on the under-manifold turbo intake and some other stuff.
Am I going to marr the surface or do any other damage by rebolting the heads to the block using the same gaskets and bolts? I wouldnt put it to full torque, just enough to hold them securely.
douglas vincent
Post by douglas vincent »
As long as you are reusing them, all should be fine.
206er
Post by 206er »
sounds like a lot more headache than its worth to pull heads with the engine in. lack of a hoist or what? 2 reasonably strong people, a piece of pipe or 2x4, and some chain/rope/straps is all you need. a third person to help guide the motor out is nice to have.
if you are just mocking some stuff up and not attempting to run them, I'd say it would be fine to just bolt em back up. you might have to put a good amount of torque on them to get them to line up with the manifold correctly though.
You need to replace the head gaskets.....bolts can be reused.
Splinter
Post by Splinter »
Legacy777 wrote:You need to replace the head gaskets.....bolts can be reused.
Im not reusing the gaskets, Im just bolting the engine together so I can work on my fabbing. The engine wont be run in that condition.
Splinter
Post by Splinter »
206er wrote:sounds like a lot more headache than its worth to pull heads with the engine in.
It's actually really easy. After watching the mechanics at work do it a few times, it looks like it might actually be easier to pull the engine this way than with a hoist.
Matt Monson
Post by Matt Monson »
I doubt it. I can get one of these engines out in less than 2 hours. You will spend at least that much time getting the heads off. Any equipment rental place will rent you a hoist for the day...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Splinter
Post by Splinter »
And will they also rent me a truck to drive it 30 miles out to my place? and a piece of level concrete to set it down on?
The car is in the dirt on the side of the road on a 20 degree lateral slope.
sammydafish
Post by sammydafish »
pulling the head with the engine in the car isn't that bad. It's easier if you pull the intake too, but can be done without (if you're doing onely one head). In any case, you'll need to pull the upper rear engine mount and jack the engine up quite a bit in order to get the head bolts to clear the frame. Plus, when torquing them down, reading a degree gauge from the angle you're forced to do it at is not to easy, but of course can be done.
- Junior
95L Wagon on T3/T4 boost :)
sammydafish
oh, and for moch up, just use the old gaskets, it's worth not accidentaly damaging a gasket and the difference in thickness is not significant enough to change the moch up on the intake side.
- Junior
95LegacyLsi
Post by 95LegacyLsi »
quickie question to join onto this thread, and that is if reusing the head bolts should you retorque to full torque spec or just tight enough??
95LegacyLsi wrote:quickie question to join onto this thread, and that is if reusing the head bolts should you retorque to full torque spec or just tight enough??
Retorque to the FSM's specs.
Splinter
Post by Splinter »
Hey, as an alternative for doing this, what do you guys think about pulling the intake, pulling the exhaust, pulling the oilpan, dropping the whole engine and tranny together onto a floor jack, lifting the front of the car, and sliding the whole thing out?
mikec
Post by mikec »
I've pulled engines and trannies like that before. But we left everything on it - Just get the front as high as you can, and leave the back end on the floor, and its not too much lifting.
dwreck30
Post by dwreck30 »
Then you would have take the crossmember and the steering rack out as well.
- Derek
'06 STi
mikec
Post by mikec »
Well, the rack would go with the crossmember, but yeah. We were doing N/A to turbo swaps, so the crossmember had to come out anyways.
