I have a 91 legacy wagon 2.5i with a a/t. I have p, r, if I put it in D it acts like it is in 2nd. If i down shift nothing happens it is still like it is in 2nd gear, but if I put it in 1st it acts like it is in park.
Can anybody help me???
trans stuck in 2nd gear
Have you checked/changed the trans fluid?
If the fluid is fine, your tranny is more then likely on the way out.
You can check to see if there's any codes stored in the trans computer. Instructions are on my site
http://www.surrealmirage.com/subaru/trans.html
Sounds like the trans is toast.
91 2.5i? uhh...
I'd agree with Josh. Sounds like the trans is toast.
Drop the pan and look for nastyness around that area. If you see a fine dust on the pan, you have found your problem.
The older AT's also had problems with the lower clutch seal that would cause slipping and whatnots.
