TPS Repair Possible?
n2x4
Post by n2x4 »
I just picked up a spare legacy with a bad TPS. You hit the gas, and the car goes nowhere. Maybe if you're lucky and play with the throttle enough, the car will move 3 feet.
Now this may be a dumb question, but can I fix the sensor on the car, or do I need a new one? I haven't really looked at it, but are there traces that could be cleaned up or something that may need to be resoldiered? Just curious if I could fix it myself.
SUBARUEHS Racing
waldo320
Post by waldo320 »
Well it is completly a sealed other than the 3 prongs sticking out of the top. I dont know if you can fix it I have an extra tps that I would be willing to sell for 30$ pm me if you are intrested.
One of the crazy's boosting a NA!
14.3 @ 93mph
The 90-94 Legacies have a 4-wire TPS, vs the newer 3-wire TPS.
I am going to make the assumption you picked up a first gen legacy.
The only adjustment is to set the idle switch, but if that were bad, that shouldn't really cause the problem you are seeing. I'd recommend just getting another one, and adjusting the new one via this information
http://www.main.experiencetherave.com:8 ... sting3.jpg
