but the fuel may need some help, Thanks for the conformation
I am working on a few projects (when work doesn't capitalize all my time
EGT moniter: several versions will be tried including a "bolt-on" four probe
version, no drilling/tapping/welding required using a single 1" x 2-1/2" LCD
display. Also in the works is a temp display using two probes which will
moniter ANY temp that a car can produce, for instance it can be used to
measure intake temps before and after the turbo, you will be able to read
the actual temp on the screen and with the push of a buttun you will be able
to read the actual temp differance between the two probes, a great testing
device. After allyou mods are finished (yea right) you can put the probes
in your trans and rear diff to moniter the temps there, actually you can put
them anywhere!
Gotta get off to work, blah.............
PeteH
-------------------------- eGroups Sponsor -------------------------~-~>
eGroups eLerts
It's Easy. It's Fun. Best of All, it's Free!
http://click.egroups.com/1/9698/2/_/_/_/971263425/
---------------------------------------------------------------------_->
