This car is one that I was going to purchase, I just don't have the time or money for another project right now.
Info that I have I got from the thread linked below:
[color=white]http://forums.nasioc.com/f ... 76[/color]
Pros:
Custom paint (DP90 ppg primer) with subaru logo on hood
2" suspension lift (outback springs and struts) 8" front ground clearance and 10" in the rear
Stainless Steel skid plate
Custom front brush guard
Aftermarket muffler
New clutch cable
New valve cover gaskets
New tierod ends
New passenger side axle
New clutch cable
New battery
Solid body only a couple rust spots
Recently replaced front brake pads (under 5k miles)
Comes with extra rear pads
Cons:
Overheating: I replaced the thermostat, rad cap, and flushed the radiator. (Edit: waterpump replaced)
Passenger side window does not work
There are a couple of pics in the link, and the current owner is a nice guy.
Best thing is that he's only looking to get $200 for it. If you have the time to do the heads, you'll have a great car for cheap.
His email is dviperlev8@yahoo.com
92 Legacy Wagon FS:NY
singincanary
