Anybody know of a cheapy flex antenna that will replace the power one located on the rear of a Turbo Wagon?
(i have successfully re-masted the sedan power antenna before, and could not get the Wagon figured out. It is ENTIRELY a different motor system, bracket, mast etc etc. The one for the wagon mounts on a vertical panel, on the quarter panel, the sedan mounts on top of the panel on the horizontal). The 2 are NOT interchangeable. The Wagon antenna retracts differently into the panel. The plastic zip gearing is not even the same styles.
I ruined the motor system on the wagon, and will not attempt another re-mast session even if i had another motor. Very personal and aggrevating experience........
I have been looking around at the junkyard to no avail. even looking on other cars for one that might work on the wagon.
Does anyone have any ideas. Currently I have a spare honda civic antenna hooked up and just lying in the rear compartment, with the hole blocked off with a plug. My reception is horrid this way, i need to get it replaced, and not much funding to do this.
power antenna for Turbo Wagon, its diff than the sedan, help
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
