High idle. Driving me crazy.
Ok, first the symptoms:
When the car is started in the mornings, it will immediately rise to about 2k. Then slowly start to fall until it stalls. I need to bump the accelerator a few times to bounce it back up until it sticks around 2k. Then it will slowly hunt down to around 1.2k and hold.
Driving around, the idle is always high. In drive, it's about 1k. After driving around, if I put it in park or neutral it goes to 1.5k or so and holds.
Not sure if it's related (although it probably is), but sometimes when slightly backing off on a spirited acceleration, the car will hesitate almost as if it's cutting fuel for a split second, but then resume with no problem.
What I've done so far:
Replaced IAC.
Reset ECU in hopes of 'relearning'.
Had PCV system checked and repaired. Few cracks here and there.
Timing belt replaced.
Replaced MAF.
Replaced air filter.
The only thing that seemed to make any remote difference was replacing the MAF. Before that, it used to go as high as 3k during the 'high' idle. A small victory.
This has been happening for a few months now, and I'm stumped. Any ideas?
* Edit: During all this time, the MBC has been removed and the car has been running at stock boost. The only actual 'modification' as of current, is a Saab 900 IC. I'd love to remove it and replace it with the stock piping once again, but unfortunately I no longer have the stock pieces at my disposal as they were all cracked and battered (hence the replacement).
Replaced IAC.
Replaced MAF.
MY93 EJ22T @ +1BAR
Does your throttle body have an adjustment screw on the top of it?
Here's some pics
http://www.main.experiencetherave.com:8 ... images/tb/
Here's some pics
Yes, and I've never so much as sneezed at it. :pLegacy777 wrote:Does your throttle body have an adjustment screw on the top of it?
Here's some pics
MY93 EJ22T @ +1BAR
Have you done anything to the throttle body?
Try turning the screw clockwise and see if that changes anything.
Sometimes it can work its way out over time.
Happened to me. I just turned it in until it idled where I wanted it, then Loc-tited the bastard.
Rio Red '91 Legacy SS
The idle stop screw and the needle valve screw on the top of the throttle body are two different things. You should not touch the idle stop screw. In your situation, adjusting the needle valve screw shouldn't hurt anything.magnux wrote:No, I haven't done anything to the throttle body. I thought I've read that touching the idle screw was a no-no?Legacy777 wrote:Have you done anything to the throttle body?
i have a 91 ss auto trans. and i have the exact same symptoms. i cleaned the idle air vavle(its was sticking a little so i used seafoam)then i replaced the pvc vavle from the DEALER!(recommended) then i replaced every vaccum hose i could reach..... and still nothing!!!! finaly i broke down and replaced the throttle body gasket and intake manifold gasket(while i had it off i painted it red:P) this helped dramatically it no longer died and had near perfect -vaccum pressure(-20psi)but it still idles high sometimes and when it idles down it only drops to 500rpm and purrs. its alot of work but the car is much less annoying and looks awsome with the painted intake. also every time i changed something i unhooked the battery for 15 mins and pressed on the brakes. i hope this helps
Yes it could.
I would check the condition of your TPS pigtail connector where it clips into the TPS and also while your at it I would look t the entire wiring to see if it has any sspots where metal wire is exposed. If there is, then tape it up cause it might be grounding the signal to another metal part of the car. Re-check the connection of TPS pigtail connector see if it cracked, broken or something is out of place. If its all there then I would have the TPS itself checked out. When I had a high idle problem I changed out my TPS pigtail cause it was broken at the clip and one of the wires wasnt sitting right so I finally changed it out and now when I start the car, it will idle for 1-2 minutes before then drop to normal operating RPMs of 750-850 rpms. It made a huge difference. While ur fiddling with the throttle body I'd clean out ur TB out with air intake cleaner, and you should notice a difference. Dont try to attempt to move the TPS itself unless u know what ur doing!
-1992 Legacy AWD Wagon-
"Leave it up to a Subaru to pull your friend with a Ford out of the mud when he gets stuck!"
Total Pullouts out of the mud or sand:
Subaru - 0 * Ford - 14 * Chevy - 2 * Dodge - 3
i had this same problem for as long as i had my car. at some points i would be idling at 3100rpm especially after hard acceleration.
i put a wrx intercooler on my car with a jimmy rigged piece if rubber for a seal between the cooler and the throttle body, this instantly ripped when i put it on, which i didnt know. another thing that was causing my idle to be high was my bov was literally sitting on my throttle body pushing my idle to "making me angry" heights.
so if you are running a top mount check your seals, it could be a post maf air leak (i was still running -20psi with the leak) or it may be something as simple as your throttle body is being blocked from closing properly.
Try reseting the TPS according to a haynes, or fsm. You should never change the throttle set screw unless somthing is wrong.
I cant remember the process but it involves some feeler gauges and a voltmeter.
BB
BB
Bruce Beveridge
Mech. Eng
'94 Impreza L- DOHC EJ22T Swapped again.
'94 SS - Swapped again, 5MT, Flipped, RIP
'94 SS - Swapped 5MT - DOHCEJ22T, VF37
Mech. Eng
Bump on all the TPS hints, adjusting the TPS i think would be hard unless you have a scanner than can show you the TPS value but if theres a procedure without the scanner go for it, also spray some brake clean or carb clean or anything presurised and cumbustable around all the gaskets and vacuum lines, if the engine speed changes you have a vacuum leak you need to track down. good luck
92 Legacy Turbo, 5sp MT, Early Large CC 20G heads, Ported custom clocked td04, Cobb catted DP, Injen SS 3" exhaust, Turbosmart MBC @ 10psi, Apexi 20g intake, custom FMIC, Fidanza 11lb flywheel, stock 05 WRX clutch
'cmon who's gonna post up a scan of the haynes manual tps setup? I remember doing it on my NA motor to change RPM restore thresholds... you know when the revs "hang" inbetween gears? you can change that according to the tps setup.
Feeler gauges and a volt meter... I remember that much
BB
BB
Bruce Beveridge
Mech. Eng
Mech. Eng
My Wagon just saarted doing this, was parked for a couple of months due to "severe cosmetic damage" (now repaired), and not it's idling around 1000-1100 in gear, and 1500 in neutral, A/C off.
It's also been hard to start (always). Have to hold the throttle up a bit when cranking or it will start and die. Would be nice to be able to just trun the key and have it run....
EJ22's should NEVER be hard to start. down to minus 40c... they should fire right up.
tahiti350 you may have other problems like a boost leak (aka vac leak) .
Generally non savvy mechanics screw with the TPS and eff it up.
If your car sat, and you changed nothing its unlikely that your TPS need calibration. Look for a boost leak.
BB
BB
Bruce Beveridge
Mech. Eng
Mech. Eng
similar but different high idle issue
I have a 91 L sw no turbo awd MT. I have had the car for some time and know it pretty well. Spanked some corvettes at an autox once, that was fun.
Anyway, got an issue of high idle.
car is warm, decent temp outside.
Car idles at 1750+- with "THE CLUTCH OUT, NOT PRESSED whether at a stop in neutral or driving in gear"
Push the clutch in and idle goes down to 750 or so. Had the standard codes is the past 22, 35, 12-fixed the temp sensor.
Now I am getting an occasional 42. Just did a vaccuum test with carb cleaner and found the only place idle changed with spray was next to the throttle body passenger side directly below the pcv valve. I assume this is the air idle control. I believe this is the code "42" also.
Anybody have some input?
Custom paint ads ten horsepower.
91 Legacy L wagon 5 spd
98 Legacy L wagon auto
Here's the scan for adjusting the TPS
http://www.main.experiencetherave.com:8 ... sting3.jpg
hard core, the idle switch, code 42 is located in the TPS. Use the instructions in the scan I just posted to adjust the Idle switch. If it can not be adjusted properly, replace the TPS.
