Driving without pulley
Splinter
Post by Splinter »
As you may have heard, I lost my crank pulley.
Ive found a garage to rent to work on the car, but its gonna be very difficult to get a towtruck up there, do you think its gonna be ok to tow my car to the bottom of the drive, and drive it up on battery?
Or will the lack of a crank pulley damage other engine internals/block?
Post by 555BCTurbo »
You should be alright as long as you are only running it momentarily...the worst that could probably happen is the timing belt could work off, but it is a non-interference motor so no biggie :D
Splinter
Post by Splinter »
I could put a pulley on it and thread on the remains of the bolt... theres some threads left on it
Post by entirelyturbo »
The timing belt should stay in place. The lips on the ends of the cam sprockets should keep it from walking off.
Best thing to do would be to have a friend follow you as you go, and jump you about every 10 minutes or so when your battery dies.
*Formerly DerFahrer*
Splinter
Post by Splinter »
Its about 1500 feet that Id have to drive it, if that.
monty's legacy
Post by monty's legacy »
my main pulley fell off doing about 75 on the highway while passing someone. that was some scary shit. I love AAA
91 Lsi 180k RIP(3-19-06) Sold for $120
93 L 134ish, Bring on the Snow Baby
Richard
Post by Richard »
Monty, did you ever find your pully?
americanyouth
Post by americanyouth »
I've driven 30 miles without it. Weight savings!
-James
'91 Legacy wagon going going GONE
'93 Impreza - v6 conversion underway
'95 Impreza rally-x toy (co-drive)
'97 OBS new daily
'98 RS shell dusty in garage.
Richard
Post by Richard »
30 miles without power steering and alternator? Come on. I'd only do that if I was in grave danger. I'm not sure the battery would even hold up. That's a half hour on the freeway.
Batteries can go a few days with a failed alternator so 1500 feet will be nothing. Lack of power steering will be the issue. If it were any further, I'd recommend draining the system to make the rack workable.
rallysam
Post by rallysam »
Yeah, evolution movement is right. It should be fine. Your battery will run the engine for a long time. Spark, ECU, and fuel pump don't use much electricity at all. The stuff that kills it is the accessories (radio, headlights, hvac) and restarting - so avoid those.
Yeah, no power steering will be very difficult. It will be much worse than just having a manual rack. Wide radius turns will be ok, but it will be almost impossible to (for example) pull into a parking space.
'00 Impr RS - sold
americanyouth
Richard wrote:30 miles without power steering and alternator? Come on. I'd only do that if I was in grave danger. I'm not sure the battery would even hold up. That's a half hour on the freeway.
Well, I figured my options were:
a) get towed 30 miles and pay $texas
b) get towed less than 30 miles and pay less
Turned out I made it the whole way!
-James
'97 OBS new daily
americanyouth
evolutionmovement wrote:Batteries can go a few days with a failed alternator so 1500 feet will be nothing. Lack of power steering will be the issue. If it were any further, I'd recommend draining the system to make the rack workable.
It's not that bad. Low speed manuvers are a pain but it doesn't require superhero strength or anything. ;-)
-James
'97 OBS new daily
I may have a small steering wheel, but you must still be a house then, since I had to use two arms at low speed and could almost not turn it when not moving. With no fluid it's tolerable.
monty's legacy
Richard wrote:Monty, did you ever find your pully?
no I ran it over and it ended the subrau dealership in Madison raped me for $700 in repairs.
Richard
Post by Richard »
that SUCKS!!!
monty's legacy
Richard wrote:that SUCKS!!!
yeah and after ignoring my idea of drilling out the busted ass bolt and retapping it, for 7 hours then they decided hey lets try that. Well needless to say that fixed it, and then three months later my pops was driving the car to work at 30 mph and it died, he figured it was just the timing belt. Nope turned out the engine lunched. Fucking cost me a ridiculous 1500 for a used fucking engine. damn that sucked, My dad said if he thought thats what it was he would have driven it into a rock and said a moose stepped out. that was a shitty few months
Splinter
Post by Splinter »
Well I managed to coax it 100 feet up my driveway, and when I say up, I mean up. My driveway is close to a 30 degree slope.
I couldnt get the damn AWIC back on, and it was pissing rain, so I just used some rubber hose and stuck the MAF housing straight onto the throttle... lol. It wont idle, of course, and seeing as there is nothing to give the MAF a clean signal as far as coherent airflow, it was surgey as all hell, but it made it.
Gonna get the battery charged up, take care of a few other details, and get it flatbedded out to the new garage tomorrow morning.
YAY! ILL BE ABLE TO WORK ON HER AGAIN <3
monty's legacy
oh yeah AAA is a wonderful thing also
Splinter
Post by Splinter »
Richard
Post by Richard »
Wow.
