I'm purchasing 6 Legacy engines from a local wrecker I do business with ..all for Vanagon conversions. The wrecker also has available an EJ22T complete engine with 160K miles. Probably not possible to start the engine, but can do a compression test as soon as I have it out of the car. Engine is complete except for the plastic air intake tube.
The EJ22 is not a popular engine for Vanagon conversions, but iff I get a good enough offer I will buy the engine along with the others and have it by the weekend.
Make an offer assuming compression is good and consistant on all cyls....you can adjust your price or back out if comp test proves otherwise. I will take that risk.
Can arrange shipping but prefer pick up in Richmond, CA. near San Francisco.
Will consider orders for other Turbo Sedan parts for the next three days that I can remove on the same day I remove the engine,.... I plan to remove all the engines by this Thursday, Oct 19th.
Make me an offer.
Warren C.
EJ22T Engine Avail- $160K Miles -San Francisco Area
SubaruVanagonguy
turbo parts
looking for intake tubing with hoses, plastic pieces that connect vacuum lines. if you have other parts near engine let me know. I take it these are engines only? thanks for time. be well, Daniel
91 SS/ 01 MB ML 55
Bronx, NY.
Bronx, NY.
SubaruVanagonguy
