Aftermarket fuel gauge for rally car??? HELP
Posted: Tue Oct 17, 2006 5:49 am
by rslegacy
I have a carbon fiber dash in the car thus eliminating the stock cluster. How do I hook up a aftermarket gauge? What are the ohms? How do I check the ohms with having duel sending units?
Car= 1990 Subaru Legacy Turbo conversion
Walbro fuel pump/stock fuel tank/stock sending units
HELP???
Posted: Tue Oct 17, 2006 6:04 pm
The two senders are wired in series, so their combined resistance gives you an overall fuel level.
Check out this thread for the resistances
http://bbs.legacycentral.org/viewtopic. ... uel+sender
Posted: Tue Oct 17, 2006 11:21 pm
by rslegacy
Cool thanks Josh!
Posted: Wed Oct 18, 2006 2:34 am
by rslegacy
NEW PROB!! What gauge will work for the ohms??? If the original owner of this post will let me know that would save me a huge headache down at the auto parts stores trial and error trial and error???
Thanks, Gabe.
Posted: Wed Oct 18, 2006 6:12 pm
I don't know. You'll have to check the specs on various aftermarket gauges and see which guages have a resistance range that is similar to the stock.
Basically, you're looking for a gauge that responds to the following range
1.0 - 5 ohms when full, and
92 - 96 ohms when empty
Posted: Thu Oct 19, 2006 1:43 am
by IronMonkeyL255
http://egauges.com/vdo_mult.asp?Type=Fu ... ies=Vision
This would likely work. I believe the bottom-most option would be the correct one.
Posted: Wed Oct 25, 2006 7:35 pm
by rslegacy
Thanks again to all the help!
