Aftermarket fuel gauge for rally car??? HELP
rslegacy
Post by rslegacy »
I have a carbon fiber dash in the car thus eliminating the stock cluster. How do I hook up a aftermarket gauge? What are the ohms? How do I check the ohms with having duel sending units?
Car= 1990 Subaru Legacy Turbo conversion
Walbro fuel pump/stock fuel tank/stock sending units
HELP???
The two senders are wired in series, so their combined resistance gives you an overall fuel level.
Check out this thread for the resistances
http://bbs.legacycentral.org/viewtopic. ... uel+sender
rslegacy
Post by rslegacy »
Cool thanks Josh!
rslegacy
Post by rslegacy »
NEW PROB!! What gauge will work for the ohms??? If the original owner of this post will let me know that would save me a huge headache down at the auto parts stores trial and error trial and error???
Thanks, Gabe.
I don't know. You'll have to check the specs on various aftermarket gauges and see which guages have a resistance range that is similar to the stock.
Basically, you're looking for a gauge that responds to the following range
1.0 - 5 ohms when full, and
92 - 96 ohms when empty
IronMonkeyL255
Post by IronMonkeyL255 »
http://egauges.com/vdo_mult.asp?Type=Fu ... ies=Vision
This would likely work. I believe the bottom-most option would be the correct one.
Rio Red '91 Legacy SS
rslegacy
Post by rslegacy »
Thanks again to all the help!
