Easy brake question
realfinn
Easy brake question
Post by realfinn »
Just replacing the brakes on the 93 for the first time. On other cars that I have replaced the brakes on new shims come with the brake pads. But when I bought the el cheapo wearever silvers there were no shims or plates...just the pads. The old pads on the car has shims. Should I reuse the old shims and clips or put the pads on with out them? Not sure that its a very big deal...
You need to use the clips....as for the shims....I think they cause more noise....but that's me.
You can reuse them if you want.
jamal
Vendor
Vendor
Post by jamal »
if you have a nice layer of grease between the pad and the shim it shouldn't be a problem. I think you should use them if possible- it provides a layer of heat insulation to the caliper/fluid and our brakes aren't all that big. I've been thinking about buying a sheet of titanium on e-bay and making shims.
realfinn
Post by realfinn »
Thanks guys.
Give www.mcmaster.com a look for material to make your own shims. Sometimes there cheap...sometimes there not. But its safer than ebay.
boro
Post by boro »
I just put Rotex pads and Brembo rotors on my 97 GT and the rears didnt have shims. no the old nor the new ones! Now the pads drag when I turn. :o(
realfinn
Post by realfinn »
I'm not sure that the shims would make them drag when you turn. The Shims are supposedly there to reduce noise. If the brakes are the same as the BC legacy then I would see if the pad moves (somewhat) freely on the end clips.
