Easy brake question
Posted: Tue Oct 24, 2006 4:45 pm
by realfinn
Just replacing the brakes on the 93 for the first time. On other cars that I have replaced the brakes on new shims come with the brake pads. But when I bought the el cheapo wearever silvers there were no shims or plates...just the pads. The old pads on the car has shims. Should I reuse the old shims and clips or put the pads on with out them? Not sure that its a very big deal...
Posted: Tue Oct 24, 2006 6:15 pm
You need to use the clips....as for the shims....I think they cause more noise....but that's me.
You can reuse them if you want.
Posted: Tue Oct 24, 2006 11:42 pm
by jamal
if you have a nice layer of grease between the pad and the shim it shouldn't be a problem. I think you should use them if possible- it provides a layer of heat insulation to the caliper/fluid and our brakes aren't all that big. I've been thinking about buying a sheet of titanium on e-bay and making shims.
Posted: Wed Oct 25, 2006 3:33 pm
by realfinn
Thanks guys.
Give
www.mcmaster.com a look for material to make your own shims. Sometimes there cheap...sometimes there not. But its safer than ebay.
Posted: Wed Nov 01, 2006 10:39 pm
by boro
I just put Rotex pads and Brembo rotors on my 97 GT and the rears didnt have shims. no the old nor the new ones! Now the pads drag when I turn.
Posted: Thu Nov 02, 2006 11:45 am
by realfinn
I'm not sure that the shims would make them drag when you turn. The Shims are supposedly there to reduce noise. If the brakes are the same as the BC legacy then I would see if the pad moves (somewhat) freely on the end clips.
