ebrake adjustment
rydeordie
ebrake adjustment
Post by rydeordie »
how do i adjust my ebrake on my 90 legacy awd wagon. it isnt working to well
1990 subaru legacy
-want to build it up for rally
-has exhuast
88rx7 TII- modded,standalone,turbo,etc
A Haynes manual has the procedure in it.
But it's not difficult.
You need to remove enough of the center console to access a couple nuts next to the lever. Remove the little panel next the lever and you can probably see them. One is the adjustment for the cable, the other is the locknut. You can only adjust it so much; apparently there's a point where the cable needs to be replaced. You want 7 or 8 clicks when applying the ebrake.
Make the adjustment at the parking brake.
There's a little screw adjuster you turn.
Here's some pics here
http://www.surrealmirage.com/subaru/images/swap/08
IronMonkeyL255
Post by IronMonkeyL255 »
Legacy777 wrote:Make the adjustment at the parking brake.
Ding ding!
It's pretty much just like adjusting drum brakes.
Rio Red '91 Legacy SS
