So I am still in the process of hooking some things up on my 92 leg turbo, and I turned the key to the on position without actually starting the vehicle. There is a clicking noise coming from the boost control solenoid and pressure exchange solenoid area. Also the fan keeps going on and off on and off. Worst of all the intake manifold filled completely with gas. So I had to loosen all the bolts and drain it. Is one of the solenoids or pressure sensor controlling the injectors? Is one of them failing? If anyone could help please do.
