Something for you AWIC guys...
Front, Top, Air, Water.
shemoves
Post by shemoves »
http://designengineering.com/products.a ... d=62&tid=1
Like water wetter (maybe you could just use water wetter) for the IC. Not sure if this has been posted yet.
Too much water wetter will cause foaming and pump cavitation.....not good. I had to suck out about half my water because I put too much water wetter in originally.
shemoves
Post by shemoves »
wow...do you mean in your radiator or AWIC? Also, how can you tell if it is cavitating?
scuzzy
Post by scuzzy »
shemoves wrote:wow...do you mean in your radiator or AWIC? Also, how can you tell if it is cavitating?
look at the liquid and see if it's foaming.
#82 M4 TRSCCA Rallycross
shemoves
Post by shemoves »
AWIC or radiator? How do you check if the water is foaming?
AWIC.
Yes, open the cap on the AWIC and you can see foam in there....
