Those yellow top STI injectors fit in some of our fuel rails and these fuel rails just bolt right in to our SOHC manifolds. No problem.
But.....
When you use the twin turbo manifold, YOU HAVE to use the twin turbo fuel rails. And these fuel rails ONLY accept the style of fuel injectors like this on the right.
So......
What I did was use the fuel rails that accept the 550 STI injectors, grind the hell out of the mounting holes, and then invert them so that the left side is on the right, and the right side is on the left.
I had to invert them because the mounting holes are on the INSIDE, versus the OUTSIDE of the fuel rail.
This also means that the fuel regulator is now on the drivers side, versus the passenger side of the manifold. So I will just have to rework the fuel lines.
But.... It will work.
