Need help installing Hella 500 fogs (mostly w/ mounting)
I recently purchased a set of Hella 500 fog lights and I need help installing them. I'm pretty sure I can figure out the wiring, but I need help mounting them. I've searched this, and some other forums, but have not found a solid write up. I'm not too inventive when it comes to drilling, sawing, grinding, etc., so I'm looking for something easy.
1993 Legacy L Wagon AWD. A pair of Hella 500 fog lights and a set of winter tires are coming in preparation for 115 inches of average annual snowfall.
My PIAAs came with the heavy duty double sided tape & it has held up for 11 yrs now. If these aren't huge with only a tiny base to stick to, that may work for you. Mine are mounted in the factory foglight spots & there isn't much solid structure to drill into in the front bumper (which is why they are in those spots).
'94 Legacy Touring wagon. Quicksilver metallic. WRX rims, Whiteline ALK, SS brakelines, GR2s, alum. coolant tank. Gone, but not forgotten
'99 NSX, Alex Zanardi edition, #11/50. All stock & red 2 go
'05 Corolla XRS
'05 Corolla XRS
