You guys may remember me having this from back in the day. It wont work with the mini battery i want so i am selling it for $75.
suncoast auto has been making bootleg versions of them for a month now but its now coming over to the US market. I found out the owners live real close to me so i offered to meet them with a couple of other cars at Pruven Performance to do the comparasion of before and after product.
this is what the manufac. says:
1. Increase the efficiency of your starter motor / Stabilize your idle speed.
2. Increase the torque & gives you a smooth sensation while shifting gears/ maintain and stabilize your engine during high rotational speed.
3. Improve and reduce the knock(pre-ignition) from your engine/ increase your throttle response
4. Improve the efficiency of your fuel combustion so you can save more fuel/ Brighter your headlight.
5. Reduce the static from the audio and highly improve the tone quality.
6. Once you improve the efficiency of your fuel combustion, it reduces the capacity of the exhaust gas emission. So it will level down the pollutants from your car and improve our air quality.
7. Improve the efficiency of the engine and achieve the goal to save fuel by 5%~20% (The result may very, based on the individual driving behavior & the type and year of your vehicle.)
8. Stabilize the idle speed of your engine.
9. Reduce the vibration from the engine and have a better smooth-going performance.
10. To thicker the low-pitched sound (Bass) of your car audio.
11. The LED will show the precise voltage from your car battery. (*Functions will be differing by types.)
the UVD stands for ultra voltage device, it looks to me like a capaciator that goes between your battery pos and neg and your alternator or distributor, if you guys know me, you know i am skeptical of everything, but hey free dyno pulls? let me check it out. After taking it apart, its not a capaciator, its more like an amplifier/capaciator. I did a bunch of pulls at Pruven, with no fans or intercooler fans, pretty ridiculous, and the numbers show that 100 mph+ no airflow = angry smoking topmount
So after about 3 baseline pulls, getting the oil thinned out, uppipe hot, and letting it cool down 10 in between each pull, we bolted the UVD on my and did no other changes. For those who know i already run a pretty sorted out grounding kit AND an optima yellow top, so id consider myself well grounded.
this is the results of the same cool down and just bolting on the product!
i was pretty impressed by this, the dip at 5000 is timing getting pulled (3 degrees to be exact from my logs) due to NO AIRFLOW thanks pruven) otherwise is holds 10 whp and torque from spool up to 6000 rpms and would have kept going without timing pulled :wallbash:
A civic with an modded h22a went on and got similar gains. Pruven was SO impressed with my graph......they bought all they brought on the spot. I was pretty impressed with them and more as i was driving home with it.....
I was still skeptical, so i gave it a whirl on the way home. I made instant boost in 5th gear roll ons. The throttle response went from stiff throttle cable to a "drive-by-wire feel" my bass no longer hurts my idle or lights dimming, the spool up transition is so smooth and quicker, the car is so quiet idling, and it just feels like a new car all over again and top end feels stronger as it doesnt feel struggling or like its going to break up. Car starts on the first two clicks. I think they are a great product for people who have gotten all the other bolt ons and want a little more oomph.
looks similar to this with grounding strap seperately, and it shows the voltage of the battery
HERE IS THE VIDEO of me pulling on the dyno, notice the smoky intercooler
http://media.putfile.com/UVDmovietest[/QUOTE]
