OK, dont know where i should post this, but a while back, my tranny was either fixed, or replaced, but after the guy did the work, my speedo started bouncing, only at low speeds though, here look!
http://www.youtube.com/watch?v=4kNeFT2VLWk
After tranny changed, the speedo bounces(VIDEO)
- quasi-mod-o
Subaru_Nation555
HobbyWrench
ericem,
You may consider pulling the speedometer cable and lubing it with lithium grease.
I periodically have the same problem at low speeds - particularly when the cable needs relubing and/or it is very cold out. It would make sense that additional friction at these slow revolutions would cause the reading to fluctuate.
Good luck.
Mike
__________________
'90 Legacy LS Wagon, EJ22, NA, 4EAT, FWD w/194K+ miles
Good luck.
Mike
__________________
IronMonkeyL255
Mine has pretty much always done it. I tried lubing the speedo cable with graphite lubricant, but it didn't seem to help much.......
Rio Red '91 Legacy SS
