i am putting an sti 257 motor in my 94 sedan, i would like to upgrade the turbo from the stock 2.2 to....????
also, i would like to replace the 2.2 injectors with something larger, i will be using a walbro pump to push fuel
what injectors can i use with the factory 2.2 rails??
lemme know what you got!!
WTB!! larger injectors, turbo
Confusion here.
If you are putting the 257 engine in, why are you not going with the Vf37, or a VF39? Also 2.2 Turbo fuel rails will not work with anything else, so you will have to swap the fuel rails. But if you are going that way- 650 cc injectors would ge good.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
- Vendor
