Awd issue??
wallgood358
Awd issue??
I recently purchased a 92 Legacy Sport with 159K. In perfect condition with little blemishes to the body and completely clean and rip free interior. So the car has been very well taken care of. HAd been sitting for a while before the guy decided to sell it. It has a bad vibration from up till about 40 mph and then smooths out. But the vibration will return under hard acceleration. I installed the FWD fuse to check it out and it went away. So i am wondering if my AWD is going bad or if something else oculd be my issue.
Check all your tires' air pressure. Run the front about 2-3 psi higher then the rear. Also check that the wear is even between all four.
If it's still doing it, you may have some issues with the AWD system, or possibly a CV axles.
wallgood358
Probably not, unless you find an extreme difference in tire circumference.
wallgood358
