Timing belt cover
Tleg93
Timing belt cover
Post by Tleg93 »
Question:
Is the plastic timing belt cover/gasket on a 91 turbo the same as one on an NA?
Another thing, what tool do you need to remove/install the oil pressure sensor?
--Scott--
1991 - Rio Red SS
Tleg93
Post by Tleg93 »
Can't anybody answer my questions? I never get any replies....
--Scott--
1991 - Rio Red SS
The covers are the same (there's five pieces), except that the turbo motor have "TURBO" molded in underneath "SUBARU". Other than that, they are the same and are interchangable.
Re: Timing belt cover
Tleg93 wrote:Another thing, what tool do you need to remove/install the oil pressure sensor?
A wrench....it's pretty standard.
Blackbart
Vendor
Vendor
Post by Blackbart »
93forestpearl wrote:The covers are the same (there's five pieces), except that the turbo motor have "TURBO" molded in underneath "SUBARU". Other than that, they are the same and are interchangable.
The center covers are not interchangable. The n/a and turbo take different water pumps, the center timing covers allow for the difference in the watr pumps, the turbo mounts the thermostat on the front, the n/a mounts it facing down.. The other four pieces are interchangable.
