Hey everybody!! I am selling my old girl, a 1994 ABM Legacy SS 5mt.
It is in good condition and has 116k miles on it. The engine runs strong and the stock turbo still blows good. The tranny shifts ok but as with many SS's 2nd and 3rd gear synchros grind if you shift in heavy on the gas. I am the second owner of this car, the first owner was a middle aged professer who still had the window stickers from the day she bought it. This car has run great and is still strong. The only things that I can think of that would need to be done is routine maintenance around this mileage. I changed the oil myself regularly, and did most of the mods myself with the help of friends on this board.
The Good: It is in good condition and has 116k miles on it. The engine runs strong and the stock turbo still blows good. There is no rust!
New parts: Front Axles, Front Rotors, Front Brake Pads
The Bad: The hood latch had a malfunction and released as I was driving down the highway and smashed into the windshield. The hood still latches and seats ok, but it is smashed up. **Update, there's a small dent in the drivers side fender from a deadbeat hit and run driver
The Ok: The tranny shifts ok but as with most First Gen Turbo Legacys, 2nd and 3rd gear synchros grind if you shift in heavy on the gas. Tires are about 40%-50% tread ware left on all seasons. Sunroof leaks during heavy rains. Normal amount of chips and dings for a car it's age. Rear Brakes will need to be done soon.
Here is the list of Upgrades and Work already done:
2003 WRX shocks w/ 30k miles on them
2003 WRX Whiteline Racing Lowering Springs
Perrin Ultra-light weight crank pulley
New Front Axles
TopSpeed 3" turbo back exhaust
WRX painted gold 16" wheels
JDM STi steering wheel
Autometer Boost gauge in dual a-pillar pod
WRX Hood Scoop molded into hood-(now in need of repair)
6.5 Infinity Kappa speakers all arround
Panasonic Head Unit
K&N drop in filter
WRX stainless steel coolant tank
New OEM replacement Rotors
WRX OEM upgrade 2 pot calipers
New Front Brake Pads
Stoptech Front Braided Stainless Steel Brake Lines
Super Blue Racing Brake Fluid
Red Line 75 w90 gear oil
Extended 02 sensor
Diamond Coil Pack
Newer Bosch platinum spark plugs
Newer Wires
New pcv valve
Extra power steering pump included
Asking price is $1800 obo.
