misfire on idle/ IAC problem?
kidwired
Post by kidwired »
I've had a rough idle once the car is warm and the car (EJ22T) stalls at stops, the misfire clears as soon as I touch the throttle. Idles fine when cold.
I changed plugs (NGK vpower) tested plug wires and seafoamed the IAC.
Today I disconected the IAC harness while running cold and RPM's went up, when I reconnected the engine dies.
Does this sound like a bad IAC?
Goodbye my sweet, parting is such sweet sorrow....1993 BC6 , Saab IC, with xtras Hallman MBC, HKS FCD , wrx exaust.
not necessarily.....but it could be.
Do you have a laptop and a way to view what the IAC duty % is?
kidwired
Post by kidwired »
no laptop, but might be able to borrow a Modus. What am I looking for?
If you have a laptop, you should be able to run vikash's scan tool and look at the duty %.
Mainly you're looking to see what the IAC duty % is.
This thread gives info on what the various values should be.
http://bbs.legacycentral.org/viewtopic. ... =scan+tool
You however don't want to jump to conclusions that the IAC valve is bad just because the duty % is outside the specified range. Usually the IAC is just responding to what the ECU is telling it to do.
subytech
Post by subytech »
This does sound like your idle air motor to me but like Legacy777 said check it out first before you go buying expensive stuff.
92 Legacy Turbo, 5sp MT, Early Large CC 20G heads, Ported custom clocked td04, Cobb catted DP, Injen SS 3" exhaust, Turbosmart MBC @ 10psi, Apexi 20g intake, custom FMIC, Fidanza 11lb flywheel, stock 05 WRX clutch
georryan
Post by georryan »
Did you ever figure out your idle issues?
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
