WTB U-shaped hose for AWIC expansion tank vent connection
I need the U-shaped preformed hose that connects to the top of the AWIC expansion tank. When I installed the AWIC I had to remove the tank, but since I've been losing water I need to put the tank back in.
I ended up cutting that hose up, and then it fell off, and I need another if anyone has one. I found something at the autoparts store that should work, but the hose is like $12. I'll get it if I can't find anything, but I thought I'd ask.
Here's a pictures of the tank & hose
http://www.main.experiencetherave.com:8 ... c/awic.jpg
mikec
Post by mikec »
Is that just an overflow hose Josh? I would think a little piece of vacuum hose (maybe loosely ziptied so it points down) would be sufficient.
Blackbart
Vendor
Vendor
Post by Blackbart »
What is th ID of the hose? Good chance I can match up something.
Yeah it's just an overflow.
I guess I could try the zip tie thing.
Frank,
I'll try and get the ID of the hose when I get home.
5/16" ID is probably the closest. A smidge larger would probably also work.
Frank,
Don't worry about it....I found something that will work.
