Horrible gas milage, but engine runs perfect? No Cels!?!?!
douglas vincent
Getting something like 10 mpg.... When I bought it a couple thousand miles ago, we were getting up to 30 mpg on the freeway. Now it getts like 100 miles to the tank.
NO gas smell
NO Cels...
Runs and drives perfect.
O2 sensor?
NO gas smell
NO Cels...
O2 sensor?
Which car is this for.....one of the wagons you recently purchased?
wallgood358
My gas mileage has been horrible too. Ive had the car for almost 2 months now, and Ill be lucky to get 20mpg just driving highway. When I got the car I changed the oil, PCV valve, and the air filter looked brand new. When I noticed my mileaged sucked I checked for codes and I had one for my CTS, so I replaced it. No difference. I havent done plugs and wires yet, so thats next. I might also swap the coil pack to an Impreza one.
00 Impreza RS
93 Legacy SS
93 Legacy SS
dscoobydoo
Curious which car this is on Douglas?
If it's the Red S/C car, then good luck finding it as you have gone beyond normal bounds on that one.
Currently on our 93 SS with the 16g and 3 inch exhaust 9 psi, I still consistently get 22 mpg.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
Re: Horrible gas milage, but engine runs perfect? No Cels!?!
people stealing gas out of the tank.douglas vincent wrote:Getting something like 10 mpg.... When I bought it a couple thousand miles ago, we were getting up to 30 mpg on the freeway. Now it getts like 100 miles to the tank.
NO gas smell
NO Cels...
O2 sensor?
if you were leaking or running rich, you'd smell it. gas is very easy to smell in very small amounts. to be missing gallon says something is happening to it.
#82 M4 TRSCCA Rallycross
sammydafish
I say O2, maybe coolant temp sensor. O2 is probably slow. Coolant temp is easy to check with a scan tool.
does it seem low on power at all? Check cam timing, could be off a tooth causing you to loose efficiency but not enough to make it run bad.
- Junior
95L Wagon on T3/T4 boost :)
I had a problem like that on my NA. Would drive it around and get around 24 mpg. Usually get around 32-34 with it. I tried everything I could think of. Turned out to be the left rear calliper holding on to the wheel just a little bit. It would break free at higher speeds so I never really noticed it. Interestingly enough I never smelled that nasty hot break smell and could never hear any real rubbing over the sound of my snow shoes. It became obvious when I heard a grinding noise. Took off the wheel and no more break pad on one side. Apparatly the pad had finally let go. (its probably stuck in the front of a dodge ram somewhere) It was pretty obvious since I had just changed the pads on the car.
Put a new calliper, disks, and pads on and she was ready to rock out at 34 mpg again.
I still can't believe it wasn't noticalbe when I drove it....sometimes you just have to shrug your sholders.
- Findlay
http://www.toolsource.com
douglas vincent
Still havent had a chance to work on the wagon (the purple one).
But since I posted, the damn dog ate the ENTIRE rubber window gasket on the rear passenger window.
And one seat belt. Damn Doofus Dog....
