How to get WRX Calipers/Rotors to Fit?????
livestrong14
Post by livestrong14 »
Hey guys,
I have a set of WRX Front Calipers and Rotors. What do I have to do to get them to fit? Do I need different caliper brackets?
Thanks,
-Devan
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
livestrong14
Bump, has anybody done the conversion?
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
dscoobydoo
Post by dscoobydoo »
As long as you have the brackets that went with the WRX calipers, they are plug n play.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
As dscoobydoo said....they're plug and play as long as you have the brackets.
You'll need the rotors to match, and you will need at least 16" wheels.
livestrong14
thanks guys, I have project mu pads and brembo slotted rotors ready to go. I won't be able to put these on until spring. (15" winter wheels/tires on right now.)
Thanks again for the info.
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
livestrong14
Can somebody take a picture of their WRX brake setup?
-Devan
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
jamal
Vendor
Vendor
Post by jamal »
Top: Legacy bracket
Bottom: WRX
You can see the wrx bracket is taller and will place the caliper farther out, and how the mounting changed from that pin set up to two sliding pins in the bracket. The bracket attaches the same way as any other one, and the caliper bolts to it.
WRX caliper:
DLC
Post by DLC »
Legacy Central
IronMonkeyL255
Post by IronMonkeyL255 »
I can't wait to do this conversion.
I picked up my brakes yesterday, now I just need to get pads and turn the rotors.
Rio Red '91 Legacy SS
DLC
Post by DLC »
I have a complete set of these, with an extra set of calipers, if anyone is interested...
Legacy Central
