How to get WRX Calipers/Rotors to Fit?????
Posted: Wed Dec 27, 2006 8:45 pm
by livestrong14
Hey guys,
I have a set of WRX Front Calipers and Rotors. What do I have to do to get them to fit? Do I need different caliper brackets?
Thanks,
-Devan
Posted: Thu Dec 28, 2006 2:53 am
by livestrong14
Bump, has anybody done the conversion?
Posted: Thu Dec 28, 2006 3:00 am
by dscoobydoo
As long as you have the brackets that went with the WRX calipers, they are plug n play.
Posted: Thu Dec 28, 2006 5:37 pm
As dscoobydoo said....they're plug and play as long as you have the brackets.
You'll need the rotors to match, and you will need at least 16" wheels.
Posted: Thu Dec 28, 2006 6:02 pm
by livestrong14
thanks guys, I have project mu pads and brembo slotted rotors ready to go. I won't be able to put these on until spring. (15" winter wheels/tires on right now.)
Thanks again for the info.
Posted: Mon Feb 19, 2007 12:29 am
by livestrong14
Can somebody take a picture of their WRX brake setup?
-Devan
Posted: Mon Feb 19, 2007 12:58 am
by jamal
Top: Legacy bracket
Bottom: WRX
You can see the wrx bracket is taller and will place the caliper farther out, and how the mounting changed from that pin set up to two sliding pins in the bracket. The bracket attaches the same way as any other one, and the caliper bolts to it.
WRX caliper:
Posted: Mon Feb 19, 2007 3:21 am
by DLC
Posted: Thu Mar 01, 2007 3:25 pm
by IronMonkeyL255
I can't wait to do this conversion.
I picked up my brakes yesterday, now I just need to get pads and turn the rotors.
Posted: Thu Mar 01, 2007 11:15 pm
by DLC
I have a complete set of these, with an extra set of calipers, if anyone is interested...
