Not so happy for me. While driving the car a few days ago it began sounding very loud. It sounds like it's in a demolition derby.
Starting it cold this morning revealed moisture on the manifold flange, after the gasket.
The left side of the manifold doesn't have these wet spots.
I'm thinking I'll have to cut off the heat shield and use high temp sealant or something.
This is closest related thread I found, but Josh's leak was at the gasket. http://bbs.legacycentral.org/viewtopic. ... haust+leak
Anybody else had this problem?
Also, the bracket that holds the front exhaust pipe to the 4EAT was broken. I think it's been like that for a while, maybe it contributed to the problem by not supporting the exhaust?
Here's my temporary replacement *cue banjo solo*
