Coil part number request
magicmike
Post by magicmike »
I am trying to buy a coil pack for my 94 t-wagon. With the VIN check at the stealership they come up with two possible replacments.
Part Number: 22433AA230 production dates 5/91 - 2/94
Part Number: 22433AA360 production dates 6/93 - 2/94
Any clue as to which one is the correct one or perhaps even the better one?
I'm guessing the ...360 one due to it being a later revision it appears. I'd like to order one today so thanks for any prompt responses.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
The 230 one looks to be more applicable. The 360 looks to be for the 1.8 l imprezas.
Put the part #'s in here, and you'll see what I'm talking about.
https://www.subarugenuineparts.com/oe_parts_cat.html
magicmike
Post by magicmike »
ok 3rd try on replying to this post. ordered the 230 due to my lookup on there by make and model vs part number. it clearly stated turbo legacy on that one and imprezza for the 360 one.
Thanks Josh
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
magicmike
Post by magicmike »
UPDATE:
finally back in town from detroit and went to pick up the 230. Got there and the guy tells me there was a technical update and they ordered the 360 and 4 new bolts due to it being thicker than the 230. I told the guy that when I ordered the 230 I specofically asked for the 230 because the 360 showed that it was meant for the imprezza. He printed out the technical bulletin that states that the 230 is no longer made and also no longer availble and that the 360 is the replacement part for the 230 and should be used. So I have the 360 and will be putting it in tonight. I dont even know if my current coil is bad but I bought one because my hesitation is so bad and I've replaced so many other parts.
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
