Installed the manual DIY boost controller, so far so good as it has removed
the 5psi boost limit. During the tuning procedure I discovered that my
stock turbo is capable of producing well over 20psi with the boost
controller installed backwards!
PeteH
-------------------------- eGroups Sponsor -------------------------~-~>
eGroups eLerts
It's Easy. It's Fun. Best of All, it's Free!
http://click.egroups.com/1/9698/2/_/_/_/972293724/
---------------------------------------------------------------------_->
Now what !!!!!!!! 2
Alan Croxford
Now what !!!!!!!! 2
Hi Pete you might want to be a little cautious about the 20 lb boost
I
have been told that the stock turbos do well until about 15 lb and
then tend to really go up in temp. I will be able to verify this soon
as a friend is building me a multichannel temp gauge that will be
good
to 2% at 2000 degrees and 5% at 500 degrees.I also want to check on
intercooler temps and a few others.
removed
that
my
> PeteH
eGroups eLerts
http://click.egroups.com/1/9698/2/_/_/_/972324555/
I
good
removed
that
my
> PeteH
eGroups eLerts
