I bought this beater BJ wagon the other day for $250. It's a 1990(?) Legacy with 275k miles on it. It could use some R&R, which thankfully won't be pricey (Front axles, struts, and a head gasket.)It'll hold for the moment, but I know it's got some work that it needs. A 2.2 N/A motor will be easy enough to find but it doesn't need it yet. Thankfully I've done plenty of my own work on my Impreza and this thing looks even easier to work on.
I fell in love with how ugly this beaten thing really is when I put 15in studded Hankook 404's w/ black steelies on it (195/65 R15). It drives like a damn tank all over this snow we've just had in Denver, CO. I swear it lifted it almost an inch, too. The AWD grip, meaty tires, and light weight let it go over just about anything. None of this snow stops it. I'm anxious for the next storm just to see what this thing does
The struts on the car are shot. However, I'm curious if I can get Baja or Outback spring/strut assemblies to fit. That alone would lift it fine for my taste (2in). Scorpion springs would work, but the Outback spring/strut combo would give it just the little upward nudge it needs and still be soft. They're supposedly the same height. If I just need the strut, top, and spring I should be able to get that anywhere.
This ugly little abortion of a car needs front axles. Can I swap my '00 RS front axles from the "blown up and being rebuilt RS"? The parts ARE there and I'm just considering the option. The boots are in tact on the front ones already there, but they click in sharp turns. I'll do the struts first and see if that helps with the clicking, but I'm not holding my breath. Right now it feels so jittery from the blown struts I know it still needs those first. However it drives straight as an arrow and will do 80mph on the interstate without flinching
After the car is registered and passes emissions, the above plans are what I have in mind. Since Nasioc and so many other boards concentrate on WRX's, what does the old school segment have to say?
