EJ20G ignitor question
Splinter
Post by Splinter »
For various reasons, I dont want to go coil on plug. I also have to put in an MSD DIS-2 system. So, anyone know how I would go about hooking the the EJ20G wiring harness and EJ22T ignitor up to the EJ22T coilpack, through the MSD?
Which ECU are you using?
Splinter
Post by Splinter »
Autronic WRX 94-96 replacement board
So you're still using the "stock" ecu which was 4-triggers....to run the ignition?
I'm not really sure how you'd convert that to a wasted spark setup...
mikec
Post by mikec »
Run the channels for cylinder 1 and 2 to the front half of the ignitor and coil, and run cylinders 3 and 4 to the other half. Stick diodes on the leads coming out of the ECU, to protect the drivers.
At least, that makes sense in my head.
Splinter
Post by Splinter »
What exactly does the ignitor do?
Matt Monson
Post by Matt Monson »
Why aren't you using a DIS-4?
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Splinter
Post by Splinter »
Havent gotten the unit yet.
Would it make it easier?
Matt Monson
Yes. It's 4 channel versus 2 channel.
Suby Hai!
Splinter
Post by Splinter »
haha! I figure it out I think.
The ignitor basically just acts as a ground control box.
All the coils get a constant 12V+ supply. When the ecu fires a cylinder, it sends a signal level pulse to the ignitor, which opens a ground path for that coil.
Therefore, if I take the USDM coilpack, hook up the 1/2 coil to both the 1 and 2 outlets of the JDM ignitor, it'll ground whenever either path is activated, so it'll run wasted spark. Also do the same for the 3/4 signals
Matt Monson
Or you could run modern WRX coils, which have individual built in ignitors. This is what I am going to do long term on my car...
Suby Hai!
Splinter
Post by Splinter »
Then I have to figure out how to wire them, and I have to buy the coils
I dont have the manifold harness for the EJ20G
