JDM 2001 legacy B4 wheels fitment on my BF?
90legacygx
Post by 90legacygx »
Hi, I have lined up a deal for a set of:
2001 Legacy B4 (JDM) wheels with 215/45R17 tyres. :-D
Will these rub on either the fender or the struts - I assume the wheels would be 17x7.5 but not sure of offset (if anyone knows width and offset for sure then that weould be helpful too.
Cheers
rad rex
Post by rad rex »
Absolutely not.......
Give me the sellers info and I'm sure I can find what car fits them :-D
-Rad
Christine has a new owner, apparently he hasn't abused her enough yet
Understeer is when you see the tree you hit in front of the car, oversteer is when you feel it in the back - Walther Röhrl
90legacygx
bump...anyone done this?
jamal
Vendor
Vendor
Post by jamal »
There's really only one way to find out. They're 7" wide. I would run that size without worry but my suspension and alignment give me a bit more room than stock.
Post by 555BCTurbo »
I have seen other 1st Gen's with those rims, the only thing that is a maybe is the tire width...but if I were to put money on it, I would say they will fit.
SP-Boxer
Post by SP-Boxer »
What is the offset? If it's 53, it doesn't matter that the tire is a 215/45/17 instead of a 215/40/17 :wink:
"I feel Legacy"
90legacygx
SP-Boxer wrote:What is the offset? If it's 53, it doesn't matter that the tire is a 215/45/17 instead of a 215/40/17 :wink:
I went and test fitted today. The offset is 55 and they DO NOT fit. The inside of the tyre rubs on the strut, JUST! Damn it I really wanted these! :evil:
