Got the wheels for "free" had to straighten one($80), tires free. And here she is......waiting to do now, the temp sensor/ball joints/tierod ends, and one axle boot. Then who knows?
1998 VW GTi VR6 5MT (SOLD)
im curious as to what suspension setup you have i like how low your car sits and with my JDM WRX 17's thats how mine should look, i need to lower my car gimme the scoop!
92 ss 275k+mi, kartboy shifter/bushings, gauges. VRG3 FCD II, NGK I'4s, TDO5-16G 4" dp CAT-less 3"tbe 4.11 gears.
92whitelegacy wrote:im curious as to what suspension setup you have i like how low your car sits and with my JDM WRX 17's thats how mine should look, i need to lower my car gimme the scoop!
I second that, and what size tires are those?
I thought the 06' wrx wheels didnt fit due to a different offset or somthin like that.
Some of the shots look like you blacked out the chrome on the sides - others not. You might want to try out if you like the look. Heard there's tape out there to do cheap and easy...
Thanks, everyone!!! The Suspension is Eibach Sportline. The wheels fit perfect(lock-to-lock), no rubbing, and I just had some 18's on it, that didn't rub. the tires are 215/45R17, RE92's. I know they are crappy, but free is free.
the ride is pretty stiff, but not bone-jarring. the RE92's have no give in the sidewall, the 215/35R18 Hankook tires I had on before were softer, now I can "feel" the road.
man are there any factory subaru wheels that dont look 200000x better on the legacy than on the car they came on?
those wheels would look pretty sweet painted gold as well.
