wanted-silicone y pipe for wrx i/c
crawlerdan
- Vendor
i need one for an 06 wrx tmic with a td-05
dscoobydoo
My suggestion is this:
Check Nasioc for the 02-05 silicone coupler
After you get it, you are then going to have to cut it ( in the straight section after the Y from the turbo) and insert a 2 inch piece to lengthen it to make it fit.
I found mine on Nasioc. They pop up every now and then.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
