Rear speakers in 93 wagon???
Oldyota83
Post by Oldyota83 »
I was checking my rear speakers in my wagon due to some cracking noises... I found some ford speakers that were put in by previous owner, my question is what fits in there?? The factory mounts are gone and I', wanting to replace them..... Any help???
1993 Legacy Wagon, 2wd, and she still purrs.
I believe standard 6-1/2" speakers should fit.
Oldyota83
Post by Oldyota83 »
How? I pulled the covers and there is no ring for a speaker to sit in or to be fastened to, it's just open above the spring mounts... I guess I could install them in the factory grill covers....Anyone else do this?
There should be some mounting brackets.
I'd see if you can get someone parting out a wagon to send you the brackets. Shouldn't be more then a couple bucks.
I believe you want 5.25" rears since it's a wagon. The mounting brackets are big beige plastic things. Keep in mind speaker depth when buying new ones, as deeper speakers may come too close to the fuel filler stuff on the right side.
Crutchfield says 6-1/2" But I'm sure you could put 5-1/4" in there as well.
