Input shaft seal..
Input shaft seal..
Does the transmission need to be cracked open to replace the input shaft seal? I think mine's in pretty bad shape.
///M
'93 Legacy SS - part out
Yep. Sure does.
Just pull off the rear, split the case, and you'll see the seal sitting there. Replace the seal, toss the case backtogether, and your good to go.
