96 ej22 build ok?
Locked
gto7419
96 ej22 build ok?
Post by gto7419 »
I just brought home a 95 ej22. I opened it up and its nice and clean inside with cross-hatching clearly visible on the cylinder walls. Will this motor interface with my 93 n/a ecu? Will I run into wiring trouble? I will be using Phase I 2.5 dohc heads with matching 2.5 intake manifold...
My plan is to also build using 2.5 crank and rods...
Is this going to be "plug and play" or am I going to have wiring issues?
Danny
500cc Shifterkart, 125cc Shifterkart, 01 MX5, 93 Legacy Wagon (DIY Turbo)
Locked
