My mod list for background on the car in question:
Legacy SS (my current daily)
VF39 (stock US STi turbo)
Custom 3" turboback exhaust
stock STi bypass valve
Napa plug wires
boost cut defender
turbologic MBC
Coolingmist stage 2 meth injection kit with 1 gal tank upgrade
I run 21 psi peak tapering off towards redline daily on 93 octane with meth injection.
there's more, but not engine related...
Jeremy:206er wrote:I'm curious about your methanol injection setup, got a few questions if you dont mind.
so you arent running an intercooler, just the injection?
where did you get yours and how much did it cost?
where do you get the methanol?
you ever run it with water?
likes/dislikes of this setup?
thanks,
Jeremy
I have no intercooler. I use the stock turbo to throttle body pipe with a modified recirc. hose for the stock STi bypass valve I'm using to hold the extra boost. The stock legacy turbo valve leaks like crazy even at pretty low boost levels. Without pressure on the top valve it opens at around 6 psi and the STi one is good to around 19 psi. With pressure on top (normal operation) the legacy one still leaks at low boost levels but the STi one is good for mid 20's or so.
I use a coolingmist stage 2 kit with the gallon tank upgrade. My shop sells the kit I use for 469. This includes a tunable progressive controller with an onboard MAP sensor. I use the custom tunabilty to make my own meth pump duty cycle per MAP table with the included software. This keeps my air/fuel in line during part throttle, spoolup, and WOT.
We sell meth for $3/gallon which seems to be about average. It's generally much cheaper at a race shop than a home improvement store like Home Depot, etc. The range seems to be 2.50-5/gallon depending on where you get it.
I've tuned a ton of cars with water, 50/50, and straight meth depending on their build and use. Straight meth generally doesn't produce optimal results, but I'm always using my own cars as test beds for various things and I wanted to do something different. On most cars I tune, 50/50 works better than straight meth since they're not using it as a fuel persay, just for cooling.
huge gain in power
much more consistant power from the lack of heat soak
saved me a ton of money in injectors, rails, fuel pump, engine management system (This car is set up for a $1006 challenge...a race where the cost of car and total build is under $1006. Yes about half of the Grassroots challenge amount. To be clear I didn't skip engine management because I thought it wouldn't help. I'd love to have a standalone ECU in the car. Engine management system tuning is what I do for a living, but this is just my budget beater. Using the stock ECU has worked pretty well and the engine is still in tip top shape).
I pop the hood and the car looks totally stock except for my downpipe and the STi bypass valve which looks stock to those who don't know the Legacy SS one is black plastic.
I don't need race gas for the car to be quick enough to have some fun.
Meth is only used while in boost so I only use around 1 gallon per tank and a half of gas during city driving and almost none during highway driving. Most of my customers use less than this.
Dislikes:
You can't run meth at certain events such as autocross. I usually do one event a year and I'd have to run water injection only. This isn't a big deal for me since I have 4 other legacy turbos, but those that autox should be aware of this. Meth is fine at the local rallyX, but not Club or ProRally (water only). Meth is fine at some road racing and drag events, but not others. Sometimes it changes your classing as well.
Notes:
At a rallyx or similar event you can go through a lot of meth since you're in boost a lot. Not a problem, just size your tank properly and/or bring extra with you.
I change my spark plugs once an oil change to make sure I don't start getting misfires. Luckily it's not a WRX and this is super easy. I use regular NGK copper plugs. This is related to running 20+ psi more than running meth, but they go hand in hand.
Get a good clutch. My ACT heavy duty clutch is spanked from the huge torque jump I get now when I hit 21 psi on the VF39 at around 3200 rpm. The clutch still holds on the street, but at rallyx the on boost/off boost transitions and jumps in torque got it slipping pretty badly. I'm putting a 6 puck disc in to stop that.
I'm going to switch to 50/50 water/meth and put the stock fuel system back to normal in the next few days to compare. I'll report back with my results.
If anyone has any questions please fire away. Before anyone gets the wrong idea, I didn't make this thread as an argument that meth injection is better than having an intercooler. That's just how I'm using it on this particular car.
