Did my uppipe this morning
douglas vincent
Post by douglas vincent »
Did this this morning.... Made the uppipe.
Parts......
Used an existing manifold flange and pipe, welding it to the extra intercooler pipe I had
The turbo flange is 2.75 opening and I had to get there from a 2" pipe, so I bought two reducers and welding them in and up!
And the finished product.
Cost me $10 for the two reducers and the flange.
Next is the downpipe and 3" exhaust. I am probably going external wastegate, if the Audi 5000 wastegate I got an EBAY is any good.
livestrong14
Post by livestrong14 »
great work man! +1,000 for inexpensive parts!
You need to stop by our shop sometime!
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
Kelly
Post by Kelly »
You water test those welds? :shock:
thehookeup
Post by thehookeup »
i love the welds buddy, they look AWESOME. do you sense my sarcasim? haha jk
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
206er
Post by 206er »
couple things about the welds-
turn up the heat for the inside 90's on the flanges, down a little for the butt welds. the heat for the weld connecting the two reducer pieces looks about perfect. some of the others I gaurantee you will crack, probably pretty quickly.
let a puddle form before you start moving
what wire setup are you using? some welds look like the wire is sticking a little bit or something.
if its flux core you ought to take some time to really learn how to use the stuff, its much harder than solid wire and gas.
you going turbo now?
douglas vincent
Finished the downpipe..... Its just 2.5" for now, didnt have any 3"
douglas vincent
thehookeup wrote:i love the welds buddy, they look AWESOME. do you sense my sarcasim? haha jk
Ummmmmmmmmm, and you're talking? :-D
douglas vincent
If I could weld aluminium, and had the oil line, the damn thing would have started tonight!
>:D
Notice how the turbo out goes so nicely into the supercharger! :)
Also notice how restricted my inlet to the turbo is :(
I plan on making a weird box thing with flat filter for the air box.....
stipro
Post by stipro »
I like it, your crazy, but I like it. Your a real enthusiest!! :-D
douglas vincent
206er wrote:couple things about the welds-
I am using .030 wire, CO2....
I am getting better. :?
on the inside of the turbo flange, I also welded the inside and ground it down, that should help alot....
scuzzy
Post by scuzzy »
Not that I'm ragging on you, but do a lot more test welding on scrap before welding a finished product that you're going to put into use - otherwise it's not going to last long.
Using pure CO2 gas, while that works, is encouraging oxide formation and will eventually trash the welds - sooner rather than later; get CO2 and Argon mix, like 80% Argon and 20% CO2
a little more expensive, but you won't get near as much splatter, the arc will be easier to control
I've also heard that a mix of 70% Argon, 28% CO2 and 2% O2 is starting to become more popular for welding steel, but I haven't used this combination myself.
Anyway, it looks like the pure CO2 is making your arc hard to control, dump it in favor of a mix and you'll have an easier time getting better :)
#82 M4 TRSCCA Rallycross
Post by 555BCTurbo »
A lot of that is not accurate...
Running pure CO2 is not really a problem, apart from it just makes it more difficult to weld...as the bead is more likely to be contaminated... Your welds don't look too bad for a beginner, or for doing it on round stuff (total PITA!)
On your next bottle fill, I would suggest running 75/25 (75% argon and 25% C02)...That is what I use and the welds turn out really nice. (plus I have been welding for a few years lol)
Scuzzy, the gas you were alluding to is AB trimix...but it is a mix of Argon, Co2, and Nitrogen...and is used for welding stainless, which requires a hotter arc...so I wouldn't recommend its use on mild steel
Keep on truckin' Doug!!
douglas vincent
All of the pipe has been stainless.
scuzzy
Post by scuzzy »
Just speaking what I know and have been taught, 555; and I thought he was using stainless, hence an argon mix would make it easier to weld.
Kelly
Post by Kelly »
Stainless is always tuff to weld hot enough, why I usually use mild for pipe sets. Dougs welder actually works pretty damn well. I used it to peice together some stainless last week, and ya, the CO2 is going away as soon as the bottle is empty. Its just kind of hard to waste what you already got especially when on a budget.
I've never had good luck with the trimix either. Sure its hot, but it really sucks just blowin through everything you touch with it.
Id just water test it, and if it cracks, fuggit. Just reach back up there and fix it when it does. :-D
Doug, I love ya man. You are an excellent friend and an inspiration to me. Cant wait to see that thing beat modded STI's.
206er
Post by 206er »
Ive heard(and there is a lot of hearsay when it comes to welding technique and specs) that pure argon is the way to go for SS.
douglas vincent
Here I am welding.
gto7419
Post by gto7419 »
hehehe, that is an awesome picture... :-D
500cc Shifterkart, 125cc Shifterkart, 01 MX5, 93 Legacy Wagon (DIY Turbo)
douglas vincent
I found an AWESOME FREE stainless bar for building brackets....
They are called knives!
Just get some stainless knives for free from the kitchen and weld them up!
Or go to Goodwill and get some for $0.25 each.....
I welded up a stainless butter knive to a stainless tube. Damn strong weld...
gto7419
Post by gto7419 »
douglas vincent wrote: Just get some stainless knives for free from the kitchen and weld them up!
Are you really married????? :shock:
thehookeup
doug im suprised she didnt kill you, or does she know. by the way awesome pic of you welding hahahahaha
Andrew
jake15
Post by jake15 »
she didn't have any way to kill him.... he welded all the knives to his car :lol:
thehookeup
jake15 wrote:she didn't have any way to kill him.... he welded all the knives to his car :lol:
i dont know why but i think that is quote of the year. hahaha
Andrew
Kelly
Post by Kelly »
And this pic of Dougs children are my new desktop. :-D
Butter knife brackets are an awesome innovation.
Kelly wrote:And this pic of Dougs children are my new desktop.
You and your box of kittens in the van. :lol:
