cable clutches
92ss satinsvoice
cable clutches
Post by 92ss satinsvoice »
from what year to what year did the impreza have the cable push type clutches?
sorry for the dumb question, but im trying to find a performence clutch for my 92ss. i have a cable clutch type.
Thanks, Andrew
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
Post by 555BCTurbo »
A performance clutch for a 98-01 2.5 RS would probably work best for your application...
Basically any clutch for a car with a Push type tranny
n2x4
Post by n2x4 »
I thought turbo legacy's always had a hydro push type clutch and NA's had the cable pull type clutch?
SUBARUEHS Racing
No....Turbo leg's always had pull hyd setups. n/a have push cable.
It sounds like Andrew has a n/a tranny.
n2x4
Post by n2x4 »
Legacy777 wrote:No....Turbo leg's always had pull hyd setups. n/a have push cable.
Ahh, ok. Thanks for confirming/correcting.
So Andrew, do you have a n/a tranny?
SUBARUEHS Racing
92ss satinsvoice
ya ive got a n/a 5mt set up. cheap way to go five speed.
thanks guys, i was starting to get a little worry'd on performence clutches for my set up.
Andy
94 L n/a 5spd, Rip
206er
Post by 206er »
I run a exedy stage 1 which you can get off ebay for 160, its supposed to be good for 300bhp or around there. also Ive heard an act 6 puck disk with a better than stock pressure plate is pretty much the strongest setup you can do with a NA trans.
92ss satinsvoice
ah nice.
hows that clutch holding for you?
what are your mods?
thanks for the info, any is greaty appresiated
Andy
94 L n/a 5spd, Rip
206er
Post by 206er »
fine, but I'm running a little under 200hp and only have about 10k miles on the clutch. I rarely dump the clutch or really shift hard either. the feel of it is great, pedal pressure is like stock.
92ss satinsvoice
im pretty hard on my drive train. slamin gears and dumpin the clutch but not from a stop. i wait till im rolling.
ive got a stock n/a clutch. its been on for almost 3k and its getting tired.
Andy
94 L n/a 5spd, Rip
I miss my old cable clutch. The feel is alot more direct. Weird huh?
92ss satinsvoice
ya i like cable over hydo. because you get feed back.
i found a 6 puck cable clutch that will work for pretty cheap.
Andy
94 L n/a 5spd, Rip
