91 Turbo 4eat not shifting gears until warm ?
KraZee
Post by KraZee »
I've had this problem for a while. When driving my suby for the 1st time ( for that day ) car wont shift between 2nd - 3rd until my temp gauge is reading normal temperature - she gets to 2nd but when I increase rpms for 3rd it 'drops out' / 'slips' to nuetral then re-engages 2nd gear. Once the temp is warm I get all 4 gears + reverse as per normal. Only happens on 1st startup or when its really cold outside regardless of time of day. Is this a gearbox or some sensor problem ?
The ATF fluid has just been recently replaced, so oil level is good.
Cheers guys
91 Legacy GT
Applied Model: BC5B49P
RHD - EJ20G - 4EAT - Sedan
The trans is designed not to shift into overdrive (4th gear) until the tranny is up to temp. It's possible something is not working properly with that......or you have an issue going on within the transmission.
If it's inside the transmission....short of tearing it apart.....it'll be hard to diagnose the problem.
KraZee
Post by KraZee »
OK - guess I'll start looking for a replacement. Have seen reco'd boxes (of same make) here in NZ on Trademe ranging from $1000 - $1400.
Many thanks.
91 Legacy GT
No problem....sorry I don't have better news.
Bheinen74
Post by Bheinen74 »
the sensor which keeps it from going into 4th is a bad idea, i hate it. It has been about 0-10 degrees here now for a week, with lows below that. Tonight the windchill is to be around -30F
When I get in my car in the morning, I warm it up, so by the time i back out the drive, it (temp guage)is approaching the middle. . but when i drive the block or so to get onto the interstate, the ATF is still cold. I am instantly running at speeds about 75mph with the tranny only going to 3rd gear, and that is not good on the engine. then, after a couple miles, the ATF heats up enough for that damn sensor to tell it to shift to 4th, and it drops the rpms back to acceptable. This is a bad design in my opinion. Why would a company design a car that way, i feel like i am gonna blow my motor, or overly stress it at the 4000 rpm it is turning, until going into 4th. :(
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
Manarius
Post by Manarius »
Gets the engine to warm up faster, prevents transmission failure - I think it was a good design idea.
The trans temp sensor is a good design. You are not going to blow up your engine. In my opinion most people are way too concerned about over revving these engines. They were designed to rev to 6500 rpm....and I'm sure there's a safety margin in there.
So you run at 3500-4000 rpm for a little bit. You'll burn a little extra gas...maybe some oil. On the flip side....if you don't have your trans fluid up to temp, you can get varnish and gummy deposits in the valves, and/or the tranny not working correctly.
Bheinen74
Post by Bheinen74 »
so.........heat.......and........cold, can kill the 4eat.
yuck.
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
