removing the rear diff
Posted: Fri Feb 02, 2007 2:45 am
by dzx
What's involved with removing the rear differential? I found a 91 turbo at the junkyard here and I'd like to grab the LSD tomorrow.
Posted: Fri Feb 02, 2007 3:32 am
by BAC5.2
Do you have any offset box wrenches? They help.
Otherwise it's not difficult. Unbolt the driveshaft, the outriggers, pull the rear axles, and unbolt the diff from the carrier. That should about do it. It's been a long time since I pulled the diff out of a Subaru (the Boostjunkie Legacy was the last one I took out) but it didn't take long and was fairly easy with the car on jackstands.
Phil
by 555BCTurbo
Axles off (punch out pins, then pull off when you drop the diff), driveline off (4 bolts), 4 12 point 17mm bolts at the front of the diff,
2 12 point 17mm bolts at the rear...
Pull forward, and its out
Posted: Fri Feb 02, 2007 3:51 am
by dzx
sweet, thanks.
Posted: Fri Feb 02, 2007 4:05 am
by AWD_addict
http://bbs.legacycentral.org/viewtopic. ... emove+diff
The pics are no longer hosted, but you can still read.
Or search.
Posted: Fri Feb 02, 2007 5:29 am
by dzx
Gracias, who'd of thought the search button could come in handy?
