Turbo to Supercharger is done.....
douglas vincent
Post by douglas vincent »
"All" done and running!
I have a pinhole exhuast leak on the downpipe, I need to wrap the turbo with insulation, and one or two other odds and ends, but the damn thing is TITS!
Of course, I still have to drive it.....
gto7419
Post by gto7419 »
Nice job - can we get some closer up pics?
Did you ever get an intake on that thing?
500cc Shifterkart, 125cc Shifterkart, 01 MX5, 93 Legacy Wagon (DIY Turbo)
Threshld1
Post by Threshld1 »
video and sound of this thing running would be amazing
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
douglas vincent
So I just took it out and drove it up and down the freeway once....... about 8 low rpm pulls, never more than 4500 rpm...
First annoying problem...
Down pipe is too "long" and exhaust hits the most minor of speed bumps.... I will have to pull the downpipe off and cut about 1-2" out of it. I will fix that pinhole leak around the downpipe turbine side flange while I am at it...
Second annoying problem...
Seems to be ALOT of oil getting jizzed everywhere.. Since its night, and now I am home from the shop, I couldnt look for where it coming from, but I am pretty sure I need to install a different bango bolt into the block, or make an inline brass restrictor.
Third problem....
Not sure, havent driven it long enough... ;D
THE GOOD NEWS>>>>>>>>>>>>>>>>>>>>>>>>>>>
IT WORKS!
Its fast as shit
8 psi at 1500 rpm
11 psi at 2500 rpm
16 psi at 3500 rpm
16 psi stays rock steady....
Its fast as shit!
4 extra psi is alot!
And I still havent taken over 4500 rpm!
Its an easy 230-240 whp right now, and you can tell...
Now to fix those problems, and get a boost controller.....
And fab some sort of air filter!
skid542
Post by skid542 »
Doug, I never really know what to tell you when you pull off these completely b*tch'n projects...
You're the man in every sense of the phrase and a true Subaru God.
We want vids with sound when you can too :).
Lee
jnorion
Post by jnorion »
I saw this in person tonight, it looks badass and it's fucking LOUD. Wish I could have ridden in it. It's crazy.
~Joel
jake15
Post by jake15 »
come to the meet i'm planning doug!!! and i can give you that front bumper skin i have for you then too :D i have to see this beast in person :lol:
n2x4
Post by n2x4 »
More pics! Looks really awesome though!
SUBARUEHS Racing
livestrong14
Post by livestrong14 »
Amazing work man! a True Subie God!
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
douglas vincent
Ok.... "good news"
90% sure I fixed the oil leak, thank god. Had a banjo bolt that wasnt tight where it connected to the oil line, and I was using a waterline banjo bolt, so I turned a brass insert, pressed it in, and drilled out a much smaller hole.... Not leaking now I think....
Redid the ENTIRE exhaust....CHRIST, if I could have, I would have paid an exhuast shop to do it. But I lifted the exhaust 2" up, so now its about 3" from the ground, still way too low, but fine for city driving... And I cut out the catalytic converter, and when I looked in it, IT WAS HOLLOW!!!!!!!! WTF?!?!? I have no clue how that happened. I didnt hollow it, I couldnt have since I didnt have a working welder until recently.... And I still passed DEQ... ?
Then I took it out again....
"bad news"
Putt putted it too the on-ramp..... got to third gear, at 2000 rpm, floored it.... Jump straight to 8-9 psi, then 12, then right up to 16, and it held it PERFECT to 6200 rpm, where I shifted.....
And POW!!!!! Blow off the fucking intake at the MAF.... So, I either need to install a 2nd BOV, or more likely, reinstall a WOT switch for the supercharger... I suspect that while I let off the throttle, which should give the BOV a vacumn signal so it would open, the supercharger was still getting a tad too much boost signal, and so stayed on for the split second it took to overboost the intake system, and blow off MAF. No big deal.
All in all, I am pretty damn happy. The motor and pull was amazing. 16psi had no knock.. I am 100% sure that 20 psi is going to be fine come this Saturday Dyno Day, as long as I get these damn annoying pesky problems out of the way.
206er
Post by 206er »
that is amazing. safe to say you are one of if not the ONLY twin charged legacy of any gen in the world, something to be damn proud of. certainly the only BC.
what kind of #'s do you think it will do on the dyno, and what are you hoping to run in the 1/4 now?
Post by BAC5.2 »
8psi at 1500rpm, that's awesome.
You have some kind of mesh or something in front of the turbo inlet?
jnorion
Post by jnorion »
BAC5.2 wrote:You have some kind of mesh or something in front of the turbo inlet?
Haha, right now you could put your finger in the turbine.
~Joel
Carbix
Post by Carbix »
why not use something like this http://cgi.ebay.ca/VW-G60-G-lader-Super ... dZViewItem
in place of the A/C looks like it would fit... just a lil fab for mounts
|====.[Legacy. Central].====|
|=+[Leaving A True Legacy]+=|
206er
Post by 206er »
they don't call those grenade60's for nothing.
G-laders are so complex. I wouldn't use that unless I had to.
Post by BAC5.2 »
Why not? It looks like a nice compact unit.
Are they just horribly inefficient?
Radial GT1
Post by Radial GT1 »
Heh, Duct tape! Teh sweet
00 Camry; No wrenchin', just drive. Thank you Japan!
93 Legacy SS 4Eat 96K; All the wrenching I could ask for.
[quote="un-named"]What a man & a woman, and another man with a sheep & a midget want to do is their own business...[/quote]
206er
Post by 206er »
BAC5.2 wrote:Why not? It looks like a nice compact unit.
yeah, also pretty undersized and problematic, plus kinda expensive compared to eatons and nowhere near as good as a lhysolm.
wtf?? :lol:
douglas vincent
I looked at those alot on EBAY.
Bang for the buck they sucked...
Reliability they sucked....
They suck.,....
My M62 is shot to shit, bearings noticable, rotors very very worn (if I replaced this unit with the "new" unit I have, I would gain 20 hp probably) but damn, it still goes!
Post by BAC5.2 »
Why is it blown up?
NICO
Post by NICO »
that thing must fucking fly WOW, was so going to do that long time ago nice work.
IronMonkeyL255
Post by IronMonkeyL255 »
This is such an awesome project.
Can't wait until it's working 100%
Rio Red '91 Legacy SS
i_c_the_light
Post by i_c_the_light »
You scare me, well done.
1990 Legacy GT wagon. 100% JDM, 100% factory.
douglas vincent
18.5 psi and 11-1 or better AFR.....
