*for a little 'custom install' I wanna try
WTB: portion of '92 SS center console.
I am looking for the smaller piece that goes under the ashtray. It has a velvety type 'sticker' on it. Rear portion surrounds the shift lever. Not sure if different colors were available, but mine is grey.
center console
Well mine is the 91 grey color interior so I believe that it will be the same as the others. I believe that you would need the center console from a Canadian model that does not have the air bag controller
94 Silver Turbo Wagon 5MT/Walbro255/SS header/STi Gn Mounts/01 RS wheels
without comparing side to side i would say this color looks very close to the "black" in my 93 and 94 USDM touring wagons. it is very much not the same as the USDM 91 SS grey color interior pieces I have.
I have noted that the Canadian model A and B pillar trim, associated with a seat belt change that i put in my 94 wagon, appears slightly more grey. I attributed it to the CAN pieces being more oxidized than the original USDM trim pieces but I could be wrong on that.
