no cat?
In all actuality, gutting cats is probably worse then leaving them in. You get a lot of turbulance in the open cavity.
Is this on a n/a or turbo car?
well thats really relative. on something like a high hp turbo or NA motor a cat or muffler of any kind will kill some power. for a stock NA legacy I bet about 1hp would be accurate.
Ive done the cat gutting on a stock NA exhaust and its not worth the effort unless your cat is broken up/clogged in which case definitely do it.
I have a few legacys, and I cleaned out the cat on my rhd, it had no noticeable affect whatsoever, the o2 censor is pre cat, so there was no cel. just make sure you have absolutely no exhaust leaks pre o2 sensor, it will decrease performance quite noticeably.
all you need is a pry bar, a hammer, and a bit of time to clean the cat out, make sure you get the wire netting and other metal out too.
Reliable + Cheap = Not Fast
Cheap + Fast = Not Reliable
Fast + Reliable = Not Cheap
91 rhd legacy wagon n/a ej22 (runs great)(never ending tranny issues)
92 lhd " wagon n/a ej22 (parts for sale)
93 lhd " sedan n/a ej22 (dont run right)
