turbo and NA 4eat direct swap?
Damon
Post by Damon »
Are the turbo and NA auto trannies a direct swap?
206er
Post by 206er »
no
voodoochylde
Post by voodoochylde »
No - OK, why not? :?
head2wind
Post by head2wind »
different final ratios, the N/A is typically 4.11, the turbos are 3.9 therefore the rear differencial will not be correct.. so you would need to put the NA diff in also... along with that the clutches are different also
94 Silver Turbo Wagon 5MT/Walbro255/SS header/STi Gn Mounts/01 RS wheels
head2wind
Post by head2wind »
doah! i said clutch... at least I didn't edit out.... :-D
voodoochylde
I think the reason he's asking (since hopefully I'm getting his '94 SS 4eat and rear diff from him) is with the rear diff and 4eat, what else is required to swap an 94 SS 4eat into a 1990 4eat NA legacy...
Damon
Post by Damon »
voodoochylde wrote:I think the reason he's asking (since hopefully I'm getting his '94 SS 4eat and rear diff from him) is with the rear diff and 4eat, what else is required to swap an 94 SS 4eat into a 1990 4eat NA legacy...
What he said. :lol:
head2wind
Post by head2wind »
If I recall properly the TCU is different but they are interchangeable. Aside from that they should be a direct interchange provided you change the rear diff also.
Bheinen74
Post by Bheinen74 »
torque converters are different.
the flexplate which is bolted to the crank is different between turbo and N/A.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
head2wind
Post by head2wind »
yes, those also... sorry, forgot that about the torque converter/flex plate.
