Aluminum Control Arms
georryan
Post by georryan »
Do we know which ones will fit on our car? I was told recently that the 02-03 wrx wagons have the same control arms as our cars, but the sedans have a different one. Does anyone know if this is true?
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
IronMonkeyL255
Post by IronMonkeyL255 »
I would think the GC impreza ones would fit.
The '02+ wrx wagons have basically the same setup as the earlier imprezas, while the sedans have a wider track. On Nasioc, a common upgrade for wagon owners is to change to sedan suspension bits and front fenders.
Rio Red '91 Legacy SS
The GC style arms are a direct replacement on our cars.
The WRX ones require some metal washers as shims for the front mount to the engine crossmember. You may want to search as others & myself have looked into it before....so I think there's some more detailed info out there.
I opted to just replace the bushings with STi bushings vs. getting the aluminum arms.
jamal
Vendor
Vendor
Post by jamal »
Legacy777 wrote:The GC style arms are a direct replacement on our cars.
The WRX wagon has wider front bushings so you'd actually have to cut a few mm off or replace them. I don't know if any US wagons got the aluminum arms though.
Post by entirelyturbo »
Yeah, jamal said it. The bushing sleeves (in any GD/GG car actually) are too long to fit in the bracket in the front crossmember.
I'll try to remember to double-check, but I believe all control arms from the BC/BF/BJ, BD/BK/BG, and GC/GF/GM (and maybe even SF) are the same.
Like IronMonkey said, the GG ones work because they have the same track and swaybar mounting brackets as ours. The GD ones have a wider track and different swaybar mounting.
You can replace the bushings in the aluminum arms with the ones out of our cars. Stand by, if I can get on a computer tomorrow, I'll get part #'s for our bushings.
I'll also try to check and see if there are aluminum arms corresponding to the GG.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
Splinter
Post by Splinter »
Anyone know the weight diff between the cast ones and the aluminum?
Shit. Judging by memory and going by estimation, the alloys' probably 3/4 the weight. I don't think they're so much for weight savings - typical Subaru they look really damn tough and I'd bet are a good deal stiffer than the steel ones. Unlike the steels, you'd likely bend the crossmember (perhaps even tear the mounting hole) before the control arm if you hit something hard.
I used the GC ones and had to cut and grind a little of the forward bushing to fit it in the crossmember, but it was an easy job and otherwise fit perfect.
I need to get this car sold before I change my mind.
I see no GC/GM aluminum arms. But the ones for the WRX wagon are B2010FE351DS, and that's for the kit.
Our front bushings, which would need to be installed in these arms (or cut the original one down like Steve did), are 20201AA000.
I don't think they sell GC arms here. I got mine from an importer in New York about five years ago. Or maybe he sent me the WRX wagon ones, but the box listed them as GC.
jamal
Vendor
Vendor
Post by jamal »
subyluvr2212 wrote:I see no GC/GM aluminum arms. But the ones for the WRX wagon are B2010FE351DS, and that's for the kit.
Are you sure that's right? On subarugenuineparts it brings up:
PT180104 R STAB KIT/
for $164.
IronMonkeyL255
I know Boxer4Racing can get them, but they will run you a cool grand.
SP-Boxer
Post by SP-Boxer »
I bought those a few weeks ago! They costed me 275 euroos, so 360 dollar or something.
Different in weight?
Check these pics! (notice, these are kilogrammes) :wink:
STEEL
ALU
"I feel Legacy"
SP-Boxer
Post by SP-Boxer »
Why do my pictures not work :o :? :(
Paste the link and you can see them :wink:
"I feel Legacy"
lets me try.
jamal
Vendor
Vendor
Post by jamal »
You guys lose at teh internets
SP-Boxer
Post by SP-Boxer »
Save them on my computer and upload them with Imageshack.... That was to much work for me :-D
But there is the difference in weight. Not a very big difference, but still 700gr on each side :o
Oh my god.... 360 dollar to lose 1.4kg :o
"I feel Legacy"
That's what I was saying - I think it's more about strength and it's probably near worthless on a street car as you can get the ball joints and bushings for the steel arms cheaper.
jamal
Vendor
Vendor
Post by jamal »
SP-Boxer wrote:Save them on my computer and upload them with Imageshack.... That was to much work for me :-D
Imageshack has a transload feature so you just give it the url and it does it for you.
Anyway, I wanted aluminum arms but think I've changed my mind and will just attempt to swap out the bushings. Actually it will likely be an ALK (~$200) since it gets you some nice new urethane bushings already in the rear mounts.
Also I think it costs more than $360 to get a set of GC aluminum arms around here.
for $164.
It's possible that it's wrong. I was looking up the SPT intake heatshield the other day, and the part number had two numbers mixed up. There's mistakes all through the SPT catalogue.
I'll get back to you all.
SP-Boxer
Post by SP-Boxer »
jamal wrote:Imageshack has a transload feature so you just give it the url and it does it for you.
Ah, ok, I didn't know that Imageshack trick :D
My aluminium arms came from the UK, but for me that's not very far offcourse :) I paid like 360 dollars, but I have seen the arms for 325 in the past. And offcourse these are USED arms...
The difference in weight is not so big, but they are stiffer and just as strong as the steel ones. Besides they look a LOT better than the original 8) I think I will polish them :smt083
"I feel Legacy"
I didn't get an answer I was happy with from SOA, it sounded like they didn't know what I was talking about.
I'll call them back on Monday.
0perose
Post by 0perose »
subyluvr2212 wrote:I didn't get an answer I was happy with from SOA, it sounded like they didn't know what I was talking about.
hey, I have a suspension question for you!
I forgot until I was just reading this thread, but it isn't related to aluminum control arms at all so I'll just send you a pm :wink:
yo mang, can I get a rootshell?
1991 N/A, 4eat, crazy lights, junk suspension, sticker wagon
1989 xt6 work in progress
bmxpunk
Post by bmxpunk »
Ok from my days as a bike geek.
Steel tends to bend and aluminum tends to break. SO what is gonna happen if you bump a curb wit hthese?
I mean you can usually limp home if something is bent, but broken and you are stranded city.
Is this just my worry-wart-itis?
2011 Mini Countryman S All4
1970 Honda Ct90
Post by BAC5.2 »
It will take a much harder hit to snap an aluminum control arm, than it will take to bend a steel control arm.
Unsprung weight loss is key. The aluminum control arms reduce the intial moment of inertia, making the suspension all the more responsive.
This doesn't mean much on the auto-x course, but it can mean a lot on an open track when you are hitting curbing at 120mph. Or when you are in the dirt, sliding at 90mph.
I think you'll pull the forward mounting eye out of the crossmember before you'd break these arms.
